Posted January 13, 201016 yr ok i got a few questions about boxes and i would love to kno the answers so i can further understand tuning a boxgross air space, port volume, port range area, physical port length, port area, and net air spacehow do these effect the box and such. if someone can please answer these questions that would be awsome
January 13, 201016 yr ok i got a few questions about boxes and i would love to kno the answers so i can further understand tuning a boxgross air space, port volume, port range area, physical port length, port area, and net air spacehow do these effect the box and such. if someone can please answer these questions that would be awsomeGross air space is the volume before displacementsPort volume is the amount airspace inside the portPort area range is the recommended minimum and maximum amount of port area, typically between 12 in2 and 16 in2 per ft3Physical port length is self explanatory, it's port length, in inches typically.NET airspace is the volume after displacements.
