This build is for a team mate of mine. Build consists of a pair of 18" Fi BTL's on a single [email protected]
Car is a 2003 VW Golf.
Enclosure specs... [email protected]
on with the pics.
terminated and dressed a few wires today.
two from the alt to the batt. (Red tech-flex)
two from the engine block to the frame. (silver)
two from the batt to the fuse holders.(red tech-flex, w/ bare wire on one end)
  • Replies 85
  • Views 7.6k
Just calculated the waste, and how much a sheet weighs. Added the batteries, subs , and amp. ~1053.59lbs will be added to the poor little VW.
I was wondering how you could fit a 15.8 cu ft box in a Golf !!!
You just build it IN the car, without rear seats ! Dam...:)
Do you plan to upgrade the car suspensions, as the weight will go up with all that wood, all these huge woofers...?
Looks good, keep the pics coming. That's some hard work.
it is taking the weight great so far. But that will change with the 7-8 65lb batteries going in the back.
thanks
wow that b!tch looks mean !!!
:popcorn: Nice craftsmanship! I'm diggin the look of the Golf too :drink40:
