Posted June 30, 200521 yr would there be a noticable difference between 70wx2 passive on my RE 6.5's and 125x4 active thru my 860? i might be getting a visonik 4208. anyone used this amp? is it any good???
June 30, 200521 yr Im shure you would notice a difference in SQ.I had/have MA amps (same as visonik) no problems at all with any of them
June 30, 200521 yr need an active x-over? i have one to maby sell<{POST_SNAPBACK}>What kind?<{POST_SNAPBACK}> ma audio
June 30, 200521 yr Author wouldn't i be able to run it 3-way off my 860?the guy told me it was 125wx4 but i looked up the model # and it said 250x4 supa...how much do you think a visonik 4channel amp would be worth. V4208 250x4@ 4ohm360x4@ 2ohm500x2@ 4ohm
June 30, 200521 yr need an active x-over? i have one to maby sell<{POST_SNAPBACK}>What kind?<{POST_SNAPBACK}> ma audio<{POST_SNAPBACK}>model #?
June 30, 200521 yr wouldn't i be able to run it 3-way off my 860?the guy told me it was 125wx4 but i looked up the model # and it said 250x4 supa...how much do you think a visonik 4channel amp would be worth. V4208 250x4@ 4ohm360x4@ 2ohm500x2@ 4ohm<{POST_SNAPBACK}>Should be around $180 or so for a new one.
June 30, 200521 yr i was running my ID chameleons passive, then switched to active on my 860 also. didnt notice too much of a difference but i only had it active for a week b4 i changed my setup. it's helping a lot more with my new setup.the 860 has a lot different feel in promode, you'd be amazed. you think the 860 is decent now, it turns into a whole different deck in network mode. you get to control each source level, choose all your xover points (theres a lot more to pick from), choose the slopes (also a lot more to choose from), and control time alignment for every single source (6channel). i recommend you go active.
June 30, 200521 yr Author i was running my ID chameleons passive, then switched to active on my 860 also. didnt notice too much of a difference but i only had it active for a week b4 i changed my setup. it's helping a lot more with my new setup.the 860 has a lot different feel in promode, you'd be amazed. you think the 860 is decent now, it turns into a whole different deck in network mode. you get to control each source level, choose all your xover points (theres a lot more to pick from), choose the slopes (also a lot more to choose from), and control time alignment for every single source (6channel). i recommend you go active.<{POST_SNAPBACK}>i was playing w/ it in pro mode for a little bit today. thats why i wanna do it. it looks like i would have ALOT more control over the sound. supa he was wanting 190 shipped for it used...w/ no endcaps.i think i might wait for a better deal, being thats more than they were new.....
June 30, 200521 yr Author That guy is a joke then.<{POST_SNAPBACK}>thanks supa. i tried to find a price somewhere but i couldn't i guess its last years amp.
July 1, 200521 yr Author the hk does 100x4rms...but this manualhttp://www.visonikcaraudio.com/sub/support/manuals/V4208.pdfsays this visonik 4208 does 250x4rms...are you sure its the same thing?
July 1, 200521 yr Model: HK-5984 x 200W RMS @ 4 Ohm Stereo4 x 400W RMS @ 2 Ohm Stereo2 x 800W RMS @ 4 Ohm MonoDimensions (H x W x L): 2.7
