Posted January 24, 201016 yr I am wiring my d2 subwoofers to 1 ohm. When looking at the diagram below the outputs from the amplifier go to different different coils. Can I have both the positive and negative amplifier outputs going to one coil and have them branch off to the other coil?http://www.the12volt.com/12voltimages/1_2ohm_dvc_1ohm.gif
January 24, 201016 yr as long as both negative and positive coils on the sub are wired together, single run from + and - to the amp is all that is needed.If you want to make it less stressful splicing everything, u can do this-Take 2 single wires, one for positive and one for negative.Make them long enough just to reach each coil and strip the ends off of each of course too.Once you have done this, take a knife or some wire strippers and put it directly on the middle of each wire. Slit a gap in the cover and spread the cover back about 1\4-1\2"Now all you gotta do is run a wire from the amp to the slit section of the wire, no bounds of spliced wire required and no fraying!You can get some T connectors if you want and cut the wire off and crimp into these connectors.
January 24, 201016 yr Author Alright thanks. That is the answer I was expecting and then some. Just wait until you see the pics man.
