Im looking at these 2 amps to power my 12" polk sub(150WRMS)
and my front SEPS.
Would you guys know which one is better in terms of quality and performance?... just base your answer with your experience and the
brand name, just in case you have'nt listen or audition this models..
its not available locally so im asking the experts on AMPS...
they are both on the same price range in Ebay, shipped.
Im leaning to power acoustik bcoz it has more power than PG though im not sure if it is over rated...
But most of the people in other forums recommend PG....
so that's make me confused... so pls help me to decide guys...
many thanks...
POWER ACOUSTIK OV4 800
* PWM Mosfet Power Supply
* Variable Low-Pass and High-Pass Crossovers
* Defeatable Bass Boost at 45 Hz
* Tri-Mode Capable
* 3-Way Protection Circuit
* Gold-Plated Input Terminals
* RCA Outputs
* RMS Power @ 4 Ohms: 85W x 4
* THD at 4-Ohm RMS Power: 0.02%
* Bridged RMS Power @ 4 Ohms: 210W x 2
* Speaker Level Inputs: Yes
* Preamp Outputs: Yes
* Built-In Crossovers: HP/LP
* Bass Boost: 18 dB
* Frequency Response: 10-30,000 Hz
* Signal to Noise Ratio: 97 dB
PHOENIX GOLD OCTANE -R5.0.4
* Independent front and rear adjustable input sensitivity controls
* Adjustable 0
go wt the pg,
pa makes some good stuff but i dont think that line is that good of quality.
so u mean PA makes this Octane-R amps
if that the case i'll go with PA coz they are more cheaper with more power than PG...
or what would you suggest?.. should i stick to PG?...
what about audiobahn?..
Actually PA make the Octane R series of amps.
by the way, how can you be so sure that PA make Octane AMPs while
PA amps were made in Korea and PG is in China?...
can you clarufy this?..
thanks
thanks
Read it in Mobile Entertainment when the Octane R series first came out. They did a review on them. They also make a lower end line of the Soundstream amps. Not sure which ones, but I know it is their cheapest, bottom of the line series. That was in the mag as well.
