Posted January 28, 201016 yr I'm going to be building a box for my friends Ram. Aero ports seem to be the only way to port this box but I've never used them before so im looking for a little help. Box will be going under the rear seat.The sub is a JL 10v3v3Box will be about 1.33ft after sub displacementTricky thing is I only have about 3 inches of height for the areo.(Rectangle box with wells on the bottom)The Rectangle part of the box will be W54.5-D13.5-H3JL Recommends 32Hz84.7 Slot Port Area
January 29, 201016 yr I don't think you can use aeros with only 3" of height. I think that even 2" aero ports are 4" total diameter on the flare. A slot port is likely the better solution. You could make it 3" tall and 4-5" wide.
January 29, 201016 yr Saw this on Ca.com Thought maybe it might be useful for you or anyone else. A Guide to Aero Ports
