Posted February 2, 201016 yr I just got the ARC-AUDIO 2500 CXL & looking for some info on it? Any one know the good & bad with these amps? For years I have used a SoundStream 10.2 & have been very happy with it. Should I swap it & run the ARC?
February 3, 201016 yr If you're happy with the Soundstream I don't see a reason to change. If you want to try it, swap the amps and try it. It'll take 10 minutes. That'll give you a better answer than any of us could.As for info on it, I'm sure you can google it and find some. Arc is a decently respected amplifier brand, so it's not terrible.
February 3, 201016 yr Arc builds solid amps.No idea which would be "better" as we have no idea what you're using it for or what you're goal is.....
