Posted February 4, 201016 yr Ok, I already have one 3512 dual 2 ohm and a single saz-1500d. just wondering if it would be ok to get another dual 2ohm 3512 and wire them down to .5 on a saz 3500, or to wire them at 2 ohm on 2 1500's? expanding in the future is a possibility too.
February 4, 201016 yr probably safer at 2 ohms on 2 1500s...plus it voids the warrenty to drop down to .5 ohms on those sundown amps, and its tougher on ur electrical system.
February 4, 201016 yr Ok, I already have one 3512 dual 2 ohm and a single saz-1500d. just wondering if it would be ok to get another dual 2ohm 3512 and wire them down to .5 on a saz 3500, or to wire them at 2 ohm on 2 1500's? expanding in the future is a possibility too.if u have d2's then u would be at 1 ohm if wired parallel so 2 saz1500s amd 2 3512d2 would be optimal
February 4, 201016 yr It can be done, but it is hard on the amp and the electrical. Do you have the electrical to back it up? If your electrical is not beefed up, POOF will go the amp!
February 4, 201016 yr Author as for the electrical, I would have a 250a alt and at least 2 hc1800's. I'm just starting this project, and am still undecided whether or not to take the sub and amp out of my work truck. Thanks for y'alls advice.
February 6, 201016 yr well running 2 1500s at 1 ohm will have each amp seeing .5, wont be under warrenty but as long as you keep voltage up you should be ok, imp rise will help out in this case rofl..... i ran 1 3518 last year and was seeing 2.5-3.5 ohms over the 20-70hz range while wired at 1ohm so you will be fine again as long as the voltage stays up Edited February 6, 201016 yr by tyoung515
February 6, 201016 yr well running 2 1500s at 1 ohm will have each amp seeing .5, wont be under warrenty but as long as you keep voltage up you should be ok, imp rise will help out in this case rofl..... i ran 1 3518 last year and was seeing 2.5-3.5 ohms over the 20-70hz range while wired at 1ohm so you will be fine again as long as the voltage stays upwont strapping 2 1500ds make 2 ohms
February 7, 201016 yr not if you run strapped at 1 ohm........ each amp will see .5 thus you will get right around full power after imp rise...... dum dum dum dum lol just read through again d2 and you probably dont want to run at .5 that might not end up well while strapped lol Edited February 7, 201016 yr by tyoung515
