Posted February 13, 201015 yr It won't matter if you get a recone..from us..or somebody else..and do the same thing, you are going to burn it up again. The coils are wound the exact same way every time as they are done on a machine..positive and negative is always the same. If you had it wired wrong and had the coils out of phase with each other they will fight each other and something will burn. IE No sound!I made a video anyways for when you get a recone...just a helpful hint and a fyi, it is foolish to get a "Hybrid" made from somebody else...there is a reason behind why we use what we use in our subs.I'll make a better video later with a real camera that isn't my phone..but here it is. Hope this helps.
