I was wondering if you offer enclosure blueprints? I can build just about anyhting, just can't design worth a crap for some reason. If you do, here is what I got and need:
Vehicle: 1989 Chevy Astro cargo van
Subs: 4 SoundStream SPLX-154 quad 1ohm 15" subs
HxWxL available for enclosure: Well, pretty much a wall, but. 46" high x 48" wide x up to 60" deep (doubt I'll ever need a box that deep unless I go with a tunnel).
Power to subs: SoundStream XXX-6500d at 1ohm on 16volts.
Tuning: 35 to 37Hz.
What used for: Bass Race 140-149.9 or higher class as well as daily driver.
Design does not have to be extravagant just get loud, look decent, and sound good.
I pretty much like the design you already have sketchuped for the quad havoc 15 enclosure. That's kind of the design I want to go with, port in center. SoundStream says 3 ft^3 per sub with an F3 of 45Hz, tuned to 34Hz. The sub specs are:
RMS Power (Watts): 1000
VOICE COIL DIAMETER (INCHES): 3
VOICE COIL IMPEDANCE (INCHES): Quad 1ohm
WOOFER DISPLACEMENT (FT3): .13
MAGNET WEIGHT (oz): 192oz
FREQUENCY RESPONSE (Hz): 20-300Hz
Fs (Hz): 34Hz
Qes: .388
Qms: 5.041
Qts: .360
Vas (Ft3): 2.31
Xmax (in.): .565
SPL (dB): 90
HOLE SIZE (INCHES): 14.25
WOOFER DEPTH (INCHES): 8.125
Thanks. hopefully we can work something out
give me a day or two and I will draw something up for you. Do you need a cut list also?
Don't really need a cut list, but if you want to do one, go ahead.
And thanks.
Just checking to see if any update on this or not? Not trying to rush you, just want to get started on the redesign of my wall.
