Posted February 26, 201016 yr Can someone explane what these charts mean?i don"t understand what these mean but the first cart being the highest at 50hz makes me think that i won't be able to hit lows well.i listen to slowed music 90% of the time i just want loud and low. i don"t really care about anything above 50hz or so.box is a 4th order 2 cubes sealed 6 ported tuned to 60hz 90sq in. of port.if i am right about not being able to hit low how can i change that? lower tuning, make chambers smaller? (8 cubes is the most space i have so can"t make chamber bigger without making other smaller)
February 26, 201016 yr It would help if you told us what graphs we're looking at, and it would also help if you would change the settings on the graphs so that the vertical scale includes all of the curve.
February 27, 201016 yr Looks like you built a bandpass that isn't geared towards playing sub-bass and has a peaky output.What is it that you are trying to understand about the curves?
February 27, 201016 yr Author Looks like you built a bandpass that isn't geared towards playing sub-bass and has a peaky output.What is it that you are trying to understand about the curves?i am aiming to get real low and loud i don"t what it to be real peaky but i don"t care much about the real high end. all the songs i have a listen to regularly the highest notes were around 55 hz. with the curves the way they are now do you wink i will get those results? or sound i change tuning or sizing of chambers?
February 27, 201016 yr Real loud and low ISN'T 4th order BP. Build a ported box, you'll have better results for your goals.
February 27, 201016 yr Author Real loud and low ISN'T 4th order BP. Build a ported box, you'll have better results for your goals.already have a ported box and i want to try something different so i figured a 4th order
February 27, 201016 yr Author heres my all of the boxes Lime Green: my current ported boxBlue: the planed 4th order from above. 6 cubes ported, 2 cubes sealed, tuned to 60hzRed: 4th order after playing with sizing and tuning. 5 cubes ported, 3 cubes sealed, tuned to 50Gaini read some guide to using Winisd and it said"When the line peaks above the flat 0 line, it tells you that there will be more power going to those frequencies within the peak than there will be elsewhere. When the line dips below flat, less power is produced. "So that means that when the lines are above the red flat line their will be less impedance raise and more power output.Red: i will have more power output from from 33 to 50hz they my current box (green) but slightly less from 50hz up.blue: i would have about the same range of frequencies as my current box (green) with more power out put.please tell me if my statements are correct.SPLRed: more lower end output then current box and slightly less 50 hz upblue: will be louder on higher end but not on lower end correct? Edited February 27, 201016 yr by ben29555
February 27, 201016 yr when you build this and put in your vehicle those charts will go out the window cause when cabin gain and other factors come into play it wont be the same. i just built one for myself for the first time with a american bass xd15 its 1.6 sealed and 4 ported@44 i dont know if i just got lucky but it has a decent range and rolls off above 45hz i wish i had a TL to see what its really doing. but all in all is sounds good and gets pretty damn loud. the only way to really know is to do. so just do it and see what happens.
February 27, 201016 yr Author when you build this and put in your vehicle those charts will go out the window cause when cabin gain and other factors come into play it wont be the same. i just built one for myself for the first time with a american bass xd15 its 1.6 sealed and 4 ported@44 i dont know if i just got lucky but it has a decent range and rolls off above 45hz i wish i had a TL to see what its really doing. but all in all is sounds good and gets pretty damn loud. the only way to really know is to do. so just do it and see what happens.ok but now im stuck between which of the 2 i should do the one tuned to 50 hz or the one tuned to 60 hzedit: a guy on smd told me this awhile ago and its how i designed my first box so you think i should just stick with that?or maby make the port tuned to 50 insted of 60band passes are tricky rule of thumb for a 15 you need 1.5 cubes sealed and for an 18 roughly 2 cubes sealed2-1 ratio is musical 3-1 both musical and spl4-1 way to peakyand there usually tuned roughly to 60 hzso for your 18 you'd need roughly an 8 cube box 2 sealed and a 3-1 ratio you'd need 6 cubes ported then comes the guessing/trial error shit and when you play with port area and what not and play with shrinking the box to dial it in Edited February 27, 201016 yr by ben29555
February 27, 201016 yr i'd say 50 and make the port big since you listen to mostly slowed music a lil lower would probly be better. im a bandpass noob hell im learning as i go so lol. like i said just try and see. if you feel like you wont gain anything from this or you dont wanna waste money just build a ported box. but if you really wanna get an idea of whats goin on you caint be afraid to fail Edited February 27, 201016 yr by CaptinPower
February 27, 201016 yr Looks like something between the red and blue lines might be what you want. Average their volumes and see what that gives you.Also, there is no way I'd ever adhere to a "rule" like a 15 needs 1.5 cubes sealed and an 18 needs 2 and the ratios and all that. Every driver is different and every driver will perform differently with both different volumes and ratios, even with the same cone area.
February 27, 201016 yr Author yellow line is in between the 2 its 5.5 cubes ported to 50 hz and 2.5 cubes sealed GainSPL Edited February 27, 201016 yr by ben29555
