Posted March 1, 201016 yr ok so i have been using nero forever now and im just really getting tired of how slow and long it takes to burn a music video dvd.my dvd player can only play mpeg too.so my questioin is what is a good way to burn music video dvds. thanks.
March 1, 201016 yr It may not be because of a fault with Nero. What kind of computer hardware are you working with? Encoding a DVD takes a lot of processing power. The only PC I've ever had that tore through encoding was my overclocked Q6600 @ 3.8Ghz. Your DVD burner could also be the culprit by have a slow burn speed.
March 1, 201016 yr Nero being slow sounds like a computer issue. Something wrong with drag n' drop?Drag n drop would not work in this scenario. If he simply opens a folder with the blank DVD and moves the video file, he just created a data disc which most likely wont play on a home theater or on the deck in your car. Edited March 1, 201016 yr by inkfx
March 1, 201016 yr Author k thnks just was wondering its my moms old pos mine motherboard fryed so i have to use hers.
