Posted March 7, 201016 yr i have two incrimator warden series subs duel 1.4 ohm coils what amp could i use to power these masive subs to there full potential
March 7, 201016 yr Author the ohm rating on the subs is wat im having probs with im having probs finding an amp with that ohm rating can find an amp with that power with no probs
March 7, 201016 yr the ohm rating on the subs is wat im having probs with im having probs finding an amp with that ohm rating can find an amp with that power with no probsDon't let the impedance fool you. IA simply lists the Re of the coils as the impedance rather than the nominal impedance like most other brands. The 1.4ohm/coil subs are basically dual 2ohm nominal impedance. So if you have two of them, you can wire them together to a nominal .5ohm or 2ohm load. Or if you were purchasing two amplifiers, you could run two 1ohm loads.
March 7, 201016 yr No need for 6k, but 6k on one sub is gnarley.AS WELL AS enclosure and installation dependent. Please do not make recommendations like that to someone who doesn't know what they are doing.
