Posted March 13, 201015 yr ok so i done some trouble shooting to figure out why im still getting voltage drops, light dimming, and why my subs turn off when i play heavy bass songs, and this is what i came acrossso today i measured for bad grounds, first i measured the battery with the car off, 12.6volts.secound i measured from the neg side of batt to chassis ground, got 0.01 as a reading on the DMM, so that means mininum resistance which is good right?i turned my car on, turned on the wiper blades front and rear, turned high beams and headlights on, and put my heater on MAX i put my HU to about 26/35 and measured the battery and it never went less than 13voltsso with everything still on, i measured the power cable and ground cable AT THE AMP, same reading 13-14 voltsthis is the part where im confused, so with all that being done, my lights still dim, and when the heavy bass drops when im driving and listening to music, my amp seems like it cut offs, but the green light always stays on, so really its just my subs that cut off for like 1-3 secondsso is it a bad ground at the amp? i have 17 feet of power cable and im running 1200 watts, do i need to upgrade my power wire to 2 gauge? Should i be worried that this will ruin my amp?heres a little background info-1995 ford explorer-130-140 amp alternator-BIG 3, 4 gauge everywhere-4 gauge amp kit from ebay-Hifonics BXI1210D 1200 watts at 1 ohm-2 12" pioneer subs-kenwood mpc 205 HU, 2 volt pre-outs thanks guys for all feed back
March 13, 201015 yr im guessing you have a bad ground to ur amp. also, u might want to run 0 gauge, just to be on the safe side. find out if ur alternator might be going bad too.
March 13, 201015 yr I would start by redoing all of your grounds and doing the Big 3 with 1/0. I only run about 600 watts right now with factory alt but get no dimming lights at full tilt because I have done the Big 3 with double 1/0. Andrew
March 13, 201015 yr x2 on the Big3 in 1/0 and checking your alternator, mine showed the same warning systems before it completely went out. Any parts store like AutoZone or Advance would be happy to do it for free!
March 14, 201015 yr Author thanks again guys for the help, so should i measure my amp ground with a DMM to see if its faulty? if so, please if you can do so nicely direct me on how to measure it.do you guys think my amp will be alright? i dont want to loose my baby.
March 14, 201015 yr Yeah, a BIG 3 isn't a BIG 3 without 1/0. Power wire can act in many funny ways....trust me. Keep your ground as short as possible and just make sure it's tapped to bare metal and firmly tight. Do the upgrade and then come back and let us know if problem solved. Edited March 14, 201015 yr by ESW
March 14, 201015 yr Check your O-rings the wire inside maybe loose. I like to solder all my wire inside the O-rings when doing the Big 3. Good Luck
March 15, 201015 yr Do you have aftermarket headlight bulbs?Your DMM I would be isn't fast enough to pick up the voltage drops. How did you set your gains?
March 15, 201015 yr Author with the harbor freight tool DMM, i used that to set my gains, just turned the dial to 200 ACV and measured for 34.0no aftermarket lights, just stock
March 15, 201015 yr It definitely isn't picking up the drops. Ford Explorers are not notorious for having such sensitive bulbs so I'd imagine you are getting quite a drop.As for the voltage you measured, it would be good to know the impedance of the load (ie calculated power). If you set the gains to the rating of the amp, you are into clipping as that amp will not do power without.
March 15, 201015 yr Author It definitely isn't picking up the drops. Ford Explorers are not notorious for having such sensitive bulbs so I'd imagine you are getting quite a drop.As for the voltage you measured, it would be good to know the impedance of the load (ie calculated power). If you set the gains to the rating of the amp, you are into clipping as that amp will not do power without.ok so whats not picking up the voltage drop? my meter? im at a 1 ohm load so 1200 watt rms at 1 ohm is 34.46volts are you trieng to say that right now my amp and subs is clipping?please explain clearer, thanks again though for the feed back
March 15, 201015 yr The meter has a capacitive display. IE there is a time constant or smoothing that is occurring. In other words, really fast voltage spikes in either direction it won't see. Volts are dropping, you just aren't measuring it.And yes, I am sure you are clipping your amp. No way that isn't at 1200w. On a real load with a distortion tester that amp will not produce its rated power. Set it at 1000w and see if your problem still exists. Conveniently for you, there is NO AUDIBLE difference between 1000w and 1200w anyways.
March 15, 201015 yr Author so what should i do? if my DMM cant read voltage drops, how can i be able to even set my gain? whats the point in even using a DMM if my amp is clipping at the rated power it claims, and if so how would i know setting it at 1000 watts is really going to be set at 1000 watts if my meter cant read it?from what every said about me set-up i thought i would be ok, but what your telling me is making me really nervous
March 15, 201015 yr Author another thing i forgot to mention is that when i measured for voltage drops at the neg and positive post at the battery, not only did i use my DMM, i used my diehard 950 portable battery, with voltage display and i used it just like the voltmeter, placed the clamps on the post to measure voltage drops, and its reading was the same aswell, so out of curiosity do you think that the portable battery can detect voltage drops, or would it be in the same category as the DMM, which it cant read voltage drops since it has really fast voltage spikes? Heres the link to the pic of my portable battery to show you guys what im talkin aboutpicture
March 15, 201015 yr The meter has a capacitive display. IE there is a time constant or smoothing that is occurring. In other words, really fast voltage spikes in either direction it won't see. Volts are dropping, you just aren't measuring it.And yes, I am sure you are clipping your amp. No way that isn't at 1200w. On a real load with a distortion tester that amp will not produce its rated power. Set it at 1000w and see if your problem still exists. Conveniently for you, there is NO AUDIBLE difference between 1000w and 1200w anyways.M5 I'm sure you know the answer to this, but the fact has slipped my mind at this moment. I think most DMMs recycle their reading 2-3 times a second and the good ones up to 5; but the human eye can detect a dimming light at 1/20th a second?I tried my best to remember lolAndrew
March 17, 201015 yr so what should i do? if my DMM cant read voltage drops, how can i be able to even set my gain? whats the point in even using a DMM if my amp is clipping at the rated power it claims, and if so how would i know setting it at 1000 watts is really going to be set at 1000 watts if my meter cant read it?from what every said about me set-up i thought i would be ok, but what your telling me is making me really nervousYou shouldn't use a DMM to set the gain, at least not at a level you aren't 1000% sure your amp can supply. However the solution is in my previous post. Turn down your gains, you won't hear a difference anyways. Conveniently for you, there is NO AUDIBLE difference between 1000w and 1200w anyways.
March 17, 201015 yr All the info above is good. I would check your battery also. You said it was resting at 12.6V? That is a low battery and could be part of your problems as well.
