in this article on how to determine the minium port area, it ask for the "effective diameter" of the driver being used....
the SSA XCON 18" is actually 18.5" outside diameter....but what is the "effective diameter" per this formula's application?
:ughdunno:
Is there a differance?
how does one determine this spec?
would sd be the appropriate spec here?
Thanks,
chop
  • Replies 77
  • Views 13.8k
  • get real dumbass, no one is going to use 29sq inches per for a daily system. what a retard. stop making like you know. and when were my recommendations proven wrong? or are you talking outta your as
  • um no i think you build the box then pick the sub... lol no shit.
  • all in all, brandon daily go with his idea and sue his ass for the cost of the wood you wasted. lol use winisd and see.
:ughdunno:
Thanks,
chop
Use Sd, if Sd was not supplied with the T/S parameters, you can use the effective diameter of the cone(in cm). As Sd = pi*(Dia/100)^2/4
The effective diameter is normally the diameter of the cone, plus 1/2 the surround, for wide roll surrounds at least.
:ughdunno:
Thanks,
chop
you sir , are awesome!
thank you very much.
