Knew what angle you were coming from, us poor boys gotta make that dollar stretch!
  • Replies 2.7k
  • Views 168.8k
  • CanUFeelMe
    CanUFeelMe
    What a Weekend @ Slamology!!! IAK bringing home 8 trophies! Woot Woot. Im gonna check with my people at Gauge and have them double and triple check on how many people we had enter as Team IAK... I kn
Small update: I got the 2 XS XP3000's ordered & should have the SAZ-3500v.2 ordered either this weekend or next. Hoping to order the subs by the end of the month & use my tax return to get the comps & 4ch.
I call you now.
  • 2 weeks later...
Ooooooooh yeah!!!! Looks like I'm about a couple of days from ordering some Sundown goodness ;)
Huh... for some reason, my battery charger is being used excessively today...
Now, for some reason.. the battery charger is now complete and un-needed for probably quite a long time now, :)
This week will be interesting...
So, basicly, I need to put a few extra bucks back for gas next weekend!!!!
hehe, no, i do not plan on showing it's potential off until it's tuned, tweaked and i am fully aware of what i just accomplished.
The following will be updated once i get to that stage today...
Currently having to re-wire some tweeters.... i forgot too, lol.
Once that's done, i have to repair one wire run then go over everything very carefully then prepare to check the following with status-
Checklist of functionality-
Head Unit Operations-
Bass amp 1
Bass amp 2
Bass amp 3
Bass amp 4
Highs amp 1
Highs amp 2
Processor 1
Processor 2
Fusing throughout-
RCA signal detection-
Voltage stability-
Current stability-
Subwoofer 1
Subwoofer 2
Subwoofer 3
Subwoofer 4
8" 1
8" 2
8" 3
8" 4
Tweeter 1
Tweeter 2
Master Relay switch
Ground Loop Detected?
AC Signal Distortion?
I will post with results once i have them...
Here is the newest update-
Head Unit Operations- PASS
Bass amp 1- PASS
Bass amp 2- PASS
Bass amp 3- PASS
Bass amp 4- PASS
Highs amp 1- PASS, but requires turn off pop eliminator.
Highs amp 2- PASS
Processor 1- PASS, induces Signal distortion that will be investigated later at low volume (1-6 out of 35)
Processor 2- FAIL, Output 4 of 4 is dead. Also induces signal distortion which attributes to volume range 1-6 of 35.
Fusing throughout- PASS
RCA signal detection- PASS
Voltage stability- PASS
Current stability- Not tested yet
Subwoofer 1- PASS
Subwoofer 2- PASS
Subwoofer 3- PASS
Subwoofer 4- PASS
8" 1- PASS
8" 2- PASS
8" 3- PASS
8" 4- PASS
Tweeter 1- PASS
Tweeter 2- PASS
Master Relay switch- PASS
Ground Loop Detected? NEGATIVE. PASS
AC Signal Distortion? YES but inaudible during playback. Will investigate later.
Well its freaking 4deg here and my batteries dont like it.
Well i hadn't driven in 3 days because i was on my bike, lol, but got in the truck today and i was at 12.1vangry2.gif
Not to mention a sticking thermostat that did open up till on the highway and went from C-H in 2 secs smh
Def need to start leaving my bat charger hooked up in the winter, i bet now my bikes battery is bad since i didn;t take it back out...lol always something
That many battery charges will most likely end up being classified as a felony!
SAZ-3500v.2 ordered & paid for :)
2-XS-XP3000's sitting @ Jeff's & getting topped off ;)
The subs will be ordered next week!
Nope, not yet. I'll text him.
new update-
Bass amp 1- PASS
Bass amp 2- PASS
Bass amp 3- PASS
Bass amp 4- PASS
Highs amp 1- PASS, but requires turn off pop eliminator.= getting better without it.
Highs amp 2- PASS
Processor 1- PASS, induces Signal distortion only at or below vol. 1!
Processor 2- FAIL, Output 4 of 4 is dead. Induced signal distortion has been eliminated..
Subwoofer 1- PASS
Subwoofer 2- PASS
Subwoofer 3- PASS
Subwoofer 4- PASS
8" 1- PASS
8" 2- PASS
8" 3- PASS
8" 4- PASS
Tweeter 1- PASS
Tweeter 2- PASS
AC Signal Distortion? YES but inaudible during playback above vol. 1
Good to see you see being able to apply some time each day on this!
Keep it up!!!
i am about to start testing where the wall is peaking at with no port and then take a cabin gain response graph of the vehicle soon to find out how this new wall will effect response.
As of right now, it sounds audibly around 57-65hz peaking with no port.
Also audibly, with 2 subs playing on ~6400w wired, it doesnt sound deafening at all.. but now have all 4 subs playing(all tuned differently, lol) so the measured peak spl numbers will be of the worst capability but response graphs do not need total tuning for accuracy.
Sweet.....did rattlebox get a hold of you?
I got in touch with him & he's gonna get the last deka batt I have. He still wants 1 more from my understanding though.
