January 8, 201313 yr Knew what angle you were coming from, us poor boys gotta make that dollar stretch!
January 10, 201313 yr Small update: I got the 2 XS XP3000's ordered & should have the SAZ-3500v.2 ordered either this weekend or next. Hoping to order the subs by the end of the month & use my tax return to get the comps & 4ch.
January 10, 201313 yr Small update: I got the 2 XS XP3000's ordered & should have the SAZ-3500v.2 ordered either this weekend or next. Hoping to order the subs by the end of the month & use my tax return to get the comps & 4ch.I call you now.
January 19, 201313 yr Ooooooooh yeah!!!! Looks like I'm about a couple of days from ordering some Sundown goodness
January 19, 201313 yr Now, for some reason.. the battery charger is now complete and un-needed for probably quite a long time now, This week will be interesting...
January 20, 201313 yr hehe, no, i do not plan on showing it's potential off until it's tuned, tweaked and i am fully aware of what i just accomplished.
January 20, 201313 yr The following will be updated once i get to that stage today...Currently having to re-wire some tweeters.... i forgot too, lol.Once that's done, i have to repair one wire run then go over everything very carefully then prepare to check the following with status-Checklist of functionality-Head Unit Operations- Bass amp 1Bass amp 2Bass amp 3Bass amp 4Highs amp 1Highs amp 2Processor 1Processor 2Fusing throughout-RCA signal detection-Voltage stability-Current stability-Subwoofer 1Subwoofer 2Subwoofer 3Subwoofer 48" 18" 28" 38" 4Tweeter 1Tweeter 2Master Relay switchGround Loop Detected?AC Signal Distortion?I will post with results once i have them...
January 22, 201313 yr Here is the newest update-Head Unit Operations- PASSBass amp 1- PASSBass amp 2- PASSBass amp 3- PASSBass amp 4- PASSHighs amp 1- PASS, but requires turn off pop eliminator.Highs amp 2- PASSProcessor 1- PASS, induces Signal distortion that will be investigated later at low volume (1-6 out of 35)Processor 2- FAIL, Output 4 of 4 is dead. Also induces signal distortion which attributes to volume range 1-6 of 35.Fusing throughout- PASSRCA signal detection- PASSVoltage stability- PASSCurrent stability- Not tested yetSubwoofer 1- PASSSubwoofer 2- PASSSubwoofer 3- PASSSubwoofer 4- PASS8" 1- PASS8" 2- PASS8" 3- PASS8" 4- PASSTweeter 1- PASSTweeter 2- PASSMaster Relay switch- PASSGround Loop Detected? NEGATIVE. PASSAC Signal Distortion? YES but inaudible during playback. Will investigate later.
January 22, 201313 yr Well its freaking 4deg here and my batteries dont like it.Well i hadn't driven in 3 days because i was on my bike, lol, but got in the truck today and i was at 12.1vNot to mention a sticking thermostat that did open up till on the highway and went from C-H in 2 secs smhDef need to start leaving my bat charger hooked up in the winter, i bet now my bikes battery is bad since i didn;t take it back out...lol always something
January 22, 201313 yr That many battery charges will most likely end up being classified as a felony!
January 22, 201313 yr SAZ-3500v.2 ordered & paid for 2-XS-XP3000's sitting @ Jeff's & getting topped off The subs will be ordered next week!
January 23, 201313 yr new update- Head Unit Operations- PASSBass amp 1- PASSBass amp 2- PASSBass amp 3- PASSBass amp 4- PASSHighs amp 1- PASS, but requires turn off pop eliminator.= getting better without it.Highs amp 2- PASSProcessor 1- PASS, induces Signal distortion only at or below vol. 1!Processor 2- FAIL, Output 4 of 4 is dead. Induced signal distortion has been eliminated..Fusing throughout- PASSRCA signal detection- PASSVoltage stability- PASSCurrent stability- Not tested yetSubwoofer 1- PASSSubwoofer 2- PASSSubwoofer 3- PASSSubwoofer 4- PASS8" 1- PASS8" 2- PASS8" 3- PASS8" 4- PASSTweeter 1- PASSTweeter 2- PASSMaster Relay switch- PASSGround Loop Detected? NEGATIVE. PASSAC Signal Distortion? YES but inaudible during playback above vol. 1
January 23, 201313 yr Good to see you see being able to apply some time each day on this!Keep it up!!!
January 23, 201313 yr i am about to start testing where the wall is peaking at with no port and then take a cabin gain response graph of the vehicle soon to find out how this new wall will effect response.As of right now, it sounds audibly around 57-65hz peaking with no port.Also audibly, with 2 subs playing on ~6400w wired, it doesnt sound deafening at all.. but now have all 4 subs playing(all tuned differently, lol) so the measured peak spl numbers will be of the worst capability but response graphs do not need total tuning for accuracy.
January 23, 201313 yr Sweet.....did rattlebox get a hold of you?I got in touch with him & he's gonna get the last deka batt I have. He still wants 1 more from my understanding though.
