Posted March 18, 201015 yr Just wanted to see what you guys think of this turbocharger for my s.u.v http://cgi.ebay.com/ebaymotors/CHEVY-BLAZER-S10-6-BOLT-T3-T4-35psi-TURBOCHARGER-400-HP_W0QQitemZ190356419641QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2c52207439 Edited March 18, 201015 yr by P.P.P
March 18, 201015 yr I'd shy away from that one. If you want a quality unit, you'll have to pay for a quality unit. That's something you're not going to want to cheap out on.
March 18, 201015 yr You will need alot more than just a turbo. Also remeber your motor if stock will not handle high amounts of boost. I would recomend going with name brand when turboing something and making sure your motor will handle the boost.
March 18, 201015 yr You can't just buy any turbo and stick it on any vehicle. What are the engine specs and exact vehicle?
March 18, 201015 yr Yeah good luck with that.All that ebay auction includes is a shitty turbo. You'll need two manifolds, cross over, waste gate, injectors, cold side piping, couplers, clamps, some way to control fueling once you increase injector sizing, larger fuel pump, etc. I also believe that engine is speed density, if not you'll need a bigger MAF most likely otherwise you risk pegging it and going lean. Figure in spending around 4-5k to do it...and THEN some.Looked at the auction some more:That turbo is far too small. It has a T3 exhaust housing with an A/R of .64. You'll literally be choking that engine. If you did get it to run and produce boost, there'd be so much backpressure on the exhaust side you'd detonate almost immediately and crack a ring land or piston. Edited March 18, 201015 yr by John Holmes
March 18, 201015 yr Squires Turbo Systems - Turbocharged Innovation!STS makes lots of rear mount kits for GM cars. Other than that I don't know of any other company that does turbos for GM cars that come in kits. Andrew
March 18, 201015 yr Personally, I'd try and find a wrecked Typhoon or Cyclone and do a transplant.Another good luck on that one.
March 20, 201015 yr Just wanted to see what you guys think of this turbocharger for my s.u.v CHEVY BLAZER S10 6 BOLT T3/T4 35psi TURBOCHARGER 400+HP : eBay Motors (item 190356419641 end time Apr-06-10 23:28:49 PDT)\LOL u joking?
