Posted April 12, 201015 yr I have the 12" SSA Xcon D1, What is the Displacement of this sub? I would guess it's 0.18 or 0.19cuft?Take a look!! It's a work of Art...
April 12, 201015 yr Did you check the specs on the site? Im positive its there.Nice breakdown there too. Cool pics.
April 12, 201015 yr Did you make those breakdown pics or find them on the website somewhere? If you made them, good job, they look great.
April 12, 201015 yr Author Did you make those breakdown pics or find them on the website somewhere? If you made them, good job, they look great.Nope I didn't fined them, I Made it using Google SketchUp 7. I'm going to remake the hole thing, I forgotten a few things. Edited April 12, 201015 yr by Snooze
April 12, 201015 yr Displacement: 0.17 cu.ft.http://www.soundsolutionsaudio.com/store/products/12%22-SSA-XCON-D1%7B47%7DD2.htmlXCON 12D2/D13" wide, 4 layer, Aluminum coilsPush terminalsPulp Fiber Cone5 progressive spidersCustom FEA optimized motorAluminum Shorting Ring3" Anodized alum. formerTriple Sandwiched LeadsHand crafted in USAWattage: 1750wRMSSpecifications:12" SSA XCON D2Re 3.7 Ohms (1.85 per coil wired in series)Fs 32.4 HzQms 5.24Qes .39Qts .37Mms 222Vas 35 lSd 480 cm^2BL 20.65SPL 86.7 1 W/1mXmax 31mmEnclosure Recommendations:Sealed: .9 - 1.25 cu.ft.Sealed: 1.35 - 1.5 cu.ft. optimalPorted: 1.75 - 2.25 cu.ft. @ 26-33hzPorted: 2.5 - 2.75 cu.ft. @ 26-33hz opt.Sub Outside Dia.: 12.500”Cut Inside Dia.: 11.150”Displacement: 0.17 cu.ft. Edited April 12, 201015 yr by BanginGMC
April 12, 201015 yr Author 12" SSA XCON D2Re 3.7 Ohms (1.85 per coil wired in series)Fs 32.4 HzQms 5.24Qes .39Qts .37Mms 222Vas 35 lSd 480 cm^2BL 20.65SPL 86.7 1 W/1mXmax 31mmEnclosure Recommendations:Sealed: .9 - 1.25 cu.ft.Sealed: 1.35 - 1.5 cu.ft. optimalPorted: 1.75 - 2.25 cu.ft. @ 26-33hzPorted: 2.5 - 2.75 cu.ft. @ 26-33hz opt.Sub Outside Dia.: 12.500”Cut Inside Dia.: 11.150”Displacement: 0.17 cu.ft.ok, BTY the Sub Outside Dia is 12.750” with Rubber seal on. Edited April 12, 201015 yr by Snooze
