We just change our Regular Luxury Liner noise barrier.
It used to be a two part composite system made up of
1 lb psf vinyl barrier
1/4" open celled foam
We just gave it an overhaul and are now shipping it out.
The new Luxury Liner is:
1.25 lbs psf
No foam
Just raw mass loaded vinyl
The price was reduced as well
Check it out here:
Second Skin Luxury Liner - Mass Loaded Vinyl Noise Barrier - 1.25 lbs psf MLV
Thanks for your attention!
ANT
nice. how would you compare to regular LL?
not like i need it but that might actually fit under my carpet
Well...
The old Luxury Liner was the 1 lb MLV laminated to the open celled foam.
This stuff is 1.25 lbs psf so it is 20% heavier for slightly better results, but you have to add alalye rof OVerkill or Overkill Pro to go along with it so more work is required.
Either way, it is good stuff!
Very affordable too
ANT
Well...
Very affordable too
ANT
aww i see i thought it would work solo. ya i dont have room under my carpet for much of anything.... not that i need to be adding anything to my car
Why does the description say it's made "of a flexible vinyl barrier and acoustical grade open cell foam" if there's no open cell foam on the product?
Hmmm...
Where does it say that?
I thought I changed all the verbiage.
ANT
:ohnoes9: :ohnoes9: right by pricing and above install instructions
"Luxury Liner is a highly effective barrier and absorber composite mat consisting of a flexible vinyl barrier and acoustical grade open cell foam. Apply Luxury Liner on top of vibration dampers to reflect the sound waves that penetrate vibration dampers and noise filter it in to the cars cabin."
Don must be taking a little market share?
Probably.
But with Second Skin growing 22% last year, it is kind of hard to tell.
ANT
whoot whoot. party at ants house
Sure thing!
Lets do it in Mexico!
ANT
Sure thing!
ANT
I'll be spending Christmas in Cancun this year.
Should be a blast!
ANT
