Posted August 1, 200520 yr I've got a few minor scratches on the upper part of the hood...I don't think they're too deep, but can anyone recommend any products to diminsh/remove them?
August 1, 200520 yr Can you catch your fingernail on them?For very minor scratches I've had luck with a scratch/swirl remover.
August 1, 200520 yr Author good news...soap, water and elbow grease took out 90% of the scuff marks that were on there.There are only a few small marks that remain, but feeling over them, it doesn't seem like the clearcoat is scratched. it looked worse than it was, apparently. Any good mark-removers?
August 1, 200520 yr Some people use Scratch-X ... I haven't been able to get great results out of it yet. I had higher expectations out of a small tube for $11-$13 CAD. The scratches are so minor that I can't even notice them by the time I finish doing everything though.For the occasional scratch I'll use:http://www.poorboysworld.com/super-swirl-removers.htmhttp://www.premiumautocare.com/fostulswmare.html I have both in my garage right now, and both work very well.
August 2, 200520 yr Something that simple, you may have luck with a simple rubbing compound found at Wal-Mart for about 99cents. If that doesn't work, you can try whatever type of scratch and swirl remover you can find. I use the hard to get, expensive stuff, so that's probably not an option for you. If you have a local auto body paint store near, take a trip there and ask them what they have. These shops are really invaluable to anal bastards like myself. They have products twice as good as the typical off-the-shelf consumer variety you can find at any auto parts store.
August 3, 200520 yr Yep yep.When i was working at my detailing job we had 3M rubbing/polishing compounds. You cant just go pick that stuff up at wal mart
August 3, 200520 yr i'm def hittin that up today, even though its supposed to be like 95 degrees. OMG
