(2x) Quad L5 Kickers in a 24cu.ft @ 18Hz, For Stage use. Could use L7 or Solo X! Oh yeah, No SoloX in 15" size. But for the L5 with 3,000w@2-ohm x2 with Peavey IPR 6000. Talking weight here so will be rolling Quad Subs. Let me know whats on your mind good or bad.
Edited by Snooze
Now if I'm going to use L7's I'll need 2 IPR 6000 running at (4-Ohm@2,000w RMS x2)
Edited by Snooze
Sorry if I don't quite see what you are trying to build. But is that a port at the top of the box going out of the back? But then the full picture it appears to me to be sealed..?
im thinking the port might be down the middle between the 2? im confused on the design aswell
Yes port is on the top, It was at the bottom but wheels are going there so i flipped it. Port is really wide and only a inch high.
So, maybe i should center the port, Huh? I wanted a tune of 18Hz that's why it is thin.
Will those be on a permenant stage, or for a traveling band or something? They look to be VERY heavy ...
For a stage I'd might tune alot higher for accoustics rather than just raw bass drivers ... just a suggestion from an old school DJ.
I really dont have much to add but...
Maybe after you are done with those, you can give them to the homeless to live in! Those things look like tanks!
Definately tune higher, 18 Hz is waaayy to low. That tuning is only loud in something with room or cabin gain, which there is none outside. Look into some pro audio drivers on www.parts-express.com. A lot of tuning I see seems to be centered around high 60s to low 70s for outdoor use.
^ :nothingtoadd: hehe
Tuning that low for outdoors isn't functional; but indoors in a medium sized room....... :peepwall:
1 inch wide port?? your not worried port noise? am i missing something here :puzzled:
Why made you go with kicker? If i read correctly your going to tune 18Hz, i see a rebuild in your future man :( a little close to double that should be nice ;)
What ever using the old "black Widdows" we used back in the day ?? :lol2: them 15s used to rock!!
Still, tune higher, atleast 40hz.
No need to tune that low.
Only if you would use it for Home Theater.
Also make the port wider, because if you have a 1" thin port it will have port noise.
Atleast 4 inch wide for the 4 L5's.
