Posted August 8, 200521 yr im going to need one, i want something high quality that will remote start, pop my hatch and be able to signal a pager, or come with one. i want as much pager range as possible. i dont know much about alarms, i had a viper on my old camaro and it was decent but this was 4 years ago. how difficult is it to install, because the shops around here want insane amounts of money, like 600 for an installed alarm. i was thinking i'd spend 150-300 on the alarm and add ons, then spend a few days installing it. anyone know of any forums like this but for alarm information?
August 9, 200521 yr I have this information for a Firebird... but imagine they are the same:Constant 12V+: Red in Ignition Switch Harness Starter: Yellow in Ignition Switch Harness Ignition: Pink in Ignition Switch Harness Accessory: Orange in Ignition Switch Harness Tach: White in Coil Brake Switch: White in Brake Switch Trunk Pin: White (-) in Cargo Compartment Light Parking Lights: Brown in Light Switch Head Lamp: Yellow in Light Switch Hood Pin: n/a, have to install your ownFactory Disarm: n/a Door Trigger: White (-) in Driver's Pin Switch Door Lock: Light Blue in Driver's Kick Panel Door Unlock: Black in Positive Trigger Horn Wire: Black (-) in Steering Column That is just information I have, I do not know if it is 100% correct. Check all wires before using them to insure that they are indeed correct. I assume no responsibility for any mistakes in the wiring information.
August 9, 200521 yr Installing alarms on older cars like that is easy do it yourself for sure. I'd look for something by DEI(viper, python, etc..) or an UNGO.
