Ok, I have a 2005 Colorado Extreme, it is a standard cab truck. I am uncertian on the size of the box that is currently in it, but I was wondering if there is enough space there to run a ported box housing 2 10" kicker L7's and do it neatly?
Right now the box I have has the Amp Flush mounted in the box behind the driver seat, and the 2 10" L5's behind the passanger seat. Sounds good as it, but looking to be a little louder! Here is a link to the truck as it is now. I posted them on Kicker's web page for this very reason.
KICKER Hooked Up
If this can be done....can the box be wrapped in glass, and painted eventually?
Thanks,
Chad
SOLO-BARICL7
Mounting Depth (IN.,CM) 6-1/4, 15.9
Mounting Cutout, Square (IN.,CM) 9-5/16, 23.7
Min Rec Sealed Box Volume (CU. FT., Liters) .66, 18.7
Max Rec Sealed Box Volume (CU. FT., Liters) 1.0, 28.3
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.25, 35.4
Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.8
SOLO-BARICL5
Mounting Depth (IN.,CM) 6-3/16, 15.7
depth between the two is not much. On paper the L7's should only be about 12.5 percent louder than the L5's, there is not a huge difference in xmax between the two. If it was my vehicle I would sell the kicker stuff, and get a Sundown amp with two ICON 10's. It will be as loud as the kickers, cheaper and sound a lot cleaner.
As far as the custom work goes anything could be done, depending on the installer and your budget.
