Posted May 18, 201015 yr I am needing to upgrade my battery, but would like to know which setup is better since they cost roughly the same amount. First I will be running an American Pro VS-1407 and a Sundown SAE-1200Dv2. I plan to upgrade my starting battery. So would it be better for the car and the stereo to run a Duralast Gold up front and a Kinetik HC800 in the back OR to run only a Kinetik HC1800?
May 18, 201015 yr I don't know anything about your alternator, vehicle accessories or how you will end up using your stereo system......but I personally would probably go for the HC1800.
