Posted May 18, 201015 yr notice the first vid amp cut off again, done big 3 and never goes below 12v continuously jamming, using 0ga amp wire, i sanded ground down good, what can it possibly be, i need even a better ground??? the gain is close to half did it by ear, and subsonic around maybe 30, lpf around 80 - 110 i believealso comment on vids itself thx Edited May 18, 201015 yr by splguy1989
May 18, 201015 yr Author ok the problem was the ground.what i did was (jus temporary to see) took some 4 ga and ran a ground from my front battery to ground on my amp, and still using the frame ground, now i will put a new vid showin some real flex without my amp cutting off
