Posted May 25, 201015 yr OK So I have a 2000 Dodge ram Standard cab, I had 2 polk audio 12s in it 1 cu sealed per woofer. They are gone now. I am trying to decide if I want to go with 1 12 in center console area, 2 8's behind the seat s or 1-2 10s. I play a wide variety of music. I want it to pound when i want it to and sound clean when I need it to. With the truck being a std cab sucks for space. I am going to run a massive audio Nano N2 800 rms amp. I dont mind taking out the center console to replace it with a box but if I can get away with putting something behind the seats and the console then would be better all around.Oh ya for clarification looking at SSA ICON 12/10 respectively or 2 True Bass 8's Edited May 25, 201015 yr by Anarchyaudio
May 25, 201015 yr Author What are your depth restrictions behind the seats?Have 11 in wide at bottom and up to 20 in tall and 4 ins wide at the top and it can span about 65 in long all the way across behind both seats and the console
May 25, 201015 yr If you want output i would have you go with 2 10's over 2 8's. That doesn't necessarily mean just because they're 8's it couldn't be louder.. BUT!There is more cone area in 10inch sub woofers, even though! Motor force > Cone Area ( I believe )I say 2 10inch ICONS IF YOU HAVE THE SPACE
May 25, 201015 yr Author If you want output i would have you go with 2 10's over 2 8's. That doesn't necessarily mean just because they're 8's it couldn't be louder.. BUT!There is more cone area in 10inch sub woofers, even though! Motor force > Cone Area ( I believe )I say 2 10inch ICONS IF YOU HAVE THE SPACE Thats my dilemma, I have seen the space requirements for the 10s and its do able. The problem I had with my 12s before was they kept hitting my seat backs, Thats what I am trying to avoid now. Thanks though
