June 4, 201016 yr Author yup. i ve emailed them a couple of times n its been more than a week now n havent got any reply yet so i guess they dont have what i want.. im very frustrated to see my stuff lying around n not able to use it .. :@
June 4, 201016 yr Do you have room for a second alternator? Maybe you could build a mounting bracket, get a larger pulley, and just add a second stock alternator.
June 4, 201016 yr Author KU40i wish i did but no.. its already very tight around the stock alternator n that is the reason why most of the ho alternator makers couldnt make me a one.. secondly i want to give that sub with 2000-2200 rms only that too with 4 ohm load.. so is there any way i could do that with my stock alt.. i really want to add some pics from my computer to show u guys the fitting n all but cant coz it just gives me an option of inserting images from the web u know .thanks for ur concern mate
June 4, 201016 yr You can't find a ho alt for a Civic ? I can't believe that.If you have A/C, maybe you can take it off and have more room for a second alt? I'm not a specialist at all. just my 2 cts.BTW, 1500-2000 watts should be enough for a btl, build a big box for the sub, and ...enjoy !
June 4, 201016 yr You have to upload your pictures onto the web somewhere. You actually have a gallery here that you could upload your pictures to. Go to the top of the forum page and click on the "gallery" tab, find your name, and upload into your own folder. Then just insert the link from that photo location into a post here (with the image tags of course).By the way, you can still install all of that equipment and run it just fine. You'll just have to keep the gain conservative and only give the sub maybe 500-1000 watts, or whatever your electrical system can support without the voltage sagging below 12. You may not get the full potential of the setup, but at least it will be something to listen to. That power range should give you plenty of volume anyways.
June 4, 201016 yr You can't find a ho alt for a Civic ? I can't believe that.If you have A/C, maybe you can take it off and have more room for a second alt? I'm not a specialist at all. just my 2 cts.BTW, 1500-2000 watts should be enough for a btl, build a big box for the sub, and ...enjoy !Yeah BS on that. Excessive Amperage makes Civic alternators galore. So does Iraggi.
June 4, 201016 yr Author @ Notorious from FWIlol i cant remove the ac as it gets really hot here. secondly yes i can give it like 1500-2000 rms but i doubt my electrical would support it as said by others. N yes they dont make asian civic models alternators coz of the tight fitting :s@KU40Thanks alot for helping me out on how to upload pictures. as u can see above there isnt any room left for the second alternator neither for a HO alternator. i already have a L7 15' in my car with 900rms n ive enjoyed it enough, just wanted to go louder than that. solving the electrical issue with my car would give me some room for my second 18' in the near future. thanks for the help n looking forward more from you johnecon2001Iraggi ahsnt emailed me back, i guess ill just call them n i hope they dont waste my dollars as ill be making an international call n that is hell expensive but i will give it a try. i already sent excessive amperage a couple of emails but no reply n its been since more than a week now.. thanks for the input.
June 4, 201016 yr Author below are the pictures of my DDZ1 amp, yes its a beast yup its NEW !!opening it up =)I wonder what is this white looking gluish thing on the sides ??!
June 4, 201016 yr Excessive has a forum that you could post in...Excessive Amperage - Realm of Excursion
June 4, 201016 yr Author johnecon2001thanks alot man. ive emailed him directly. hope he has something for meThanks
June 5, 201016 yr I hope you didn't void your warranty by opening the amp up. A lot of manufacturers specify that.I would guess the white stuff is non-conductive glue to hold the mosfets in place.
June 5, 201016 yr Author KU40DD already dont support warranties or claims in my country, no brand does except for the Pioneer. u only will see pioneer cheap subs n chinese fake amps n nothing more. i have the only DDZ1 amp in my country already so let alone the warranty on that . btw if u ever wanted to check what goes in my country in car audio u can check the site pakwheelsDOTcom. Any how m still looking for some suggestions.. i guess im not gna call any HO alt makers today as it would be late there. i will probably call them tomorrow morning. btw its 7:36 am here.Thanks for your help man
June 11, 201016 yr Author Good news!Nate from Excessive amperage has hooked me up with the greatest deal for my car. i will be ordering a HO alt of 180 amp. Thanks Johnecon2001 for refering me to the right direction.I cant wait to grab that alternator Thanks alot to all of you guys for helping me out Riz
