Posted May 28, 201015 yr June 19th Newark Del.. Nspl / dbdrag event Nspl will be a 2x point . Dbdrag is a 1x point event ... Then June 27th 2010 Usaudio Glen Burnie M.d Nspl comp 2x point event plus King of the kick bass boxing ... I will post some vid's from the May 16th audio event .. Edited May 28, 201015 yr by beajay25
May 28, 201015 yr Author June 19th Newark Del.. Nspl / dbdrag event Nspl will be a 2x point . Dbdrag is a 1x point event ... Then June 27th 2010 Usaudio Glen Burnie M.d Nspl comp 2x point event plus King of the kick bass boxing ... I will post some vid's from the May 16th audio event .. Beajay25 warming up the warden's with them low's
May 28, 201015 yr Author 159.2 + thug Motivation 101 1st run only used 9.956 watts rms clamped 1 alt 2nd alt turned off ... The slight pause in music was not a clipp or cd skip .. It was me to see the scoreboard it looks like jello at this volume tunned 30 hz . From the driver seat 12 volt daily driver
May 28, 201015 yr Author 2nd run 159.3 next show ill play something a lil louder I think i maxed jeezy out ... again the pause was to see the score ... Enjoy pleez Im in the points race for Nspl finals 5k to 10k ... I will see yall there Full power Edited May 28, 201015 yr by beajay25
May 28, 201015 yr Good scores man!!!! still waiting to see the 160'sDo you get into the 160's with door open?
