Posted August 23, 200520 yr Ok, yesterday, I rearranged some things behind my head unit, which was working fine. I put everything back and the HU was working fine. After putting my dash back together I was planning on going to my friends apartment, but when I go to turn on the headlights a fuse blows and my dash lights cut out. I try replacing the fuse and when it blows again I check a few things and say screw it and go inside. CD player still works fine.Today I test things out better. I figured out that when the HU was not wired up the problem does not exist. When I plug the HU back in the fuse blows and such. As a matther of fact the voltage at the battery (all wires still connected) I get 56volts. If I then unplug the HU the voltage stays high for a few minutes then returns to normal.Best as I can tell the only thing that the high voltage hurt was the fuse for my taillights/dashlights, everything else ran as usual. This has me seriously stumped.The HU is a Alpine 9835 BTW.What should I check/try? Bring it.
August 23, 200520 yr WTF??something is crossed somewhere...lol...good luck!!wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
August 23, 200520 yr Author Thing that is confusing me so much is that I didn't change the wiring at all, I just unplugged the harness and moved stuff around, then plugged it back in. I don't even know where to begin really.
August 23, 200520 yr Something is wrong with the meter as well. No wway it could possibly read 56 volts. If it is, something is wrong with it. If you were seeing a true 56 volts, your vehicle would be black and crispy by now.
August 23, 200520 yr Author Yeah, I probably should change the batteries. I'll do that and try again.
August 23, 200520 yr Yeah, I probably should change the batteries. I'll do that and try again.<{POST_SNAPBACK}>Yes, do that
August 23, 200520 yr Author well, I couldn't find out what the voltage really is... cause the way I installed the headunit the last time fixed it, so today after work I'll be soldering/heatshrinking all connections, then I'll wrap the whole harness with e-tape to prevent anything from touching anything. Then I'll see if I can manage to blow that damn fuse, if not I'll know I've done it right.
August 23, 200520 yr Thats not even possible to get 56V out of a 12V battery.No, but all the other accesories, alt, caps, etc. . . . could be sending voltage back through.
August 24, 200520 yr Author HU is now 100% properly installed. If something else goes wrong with it, I know this really, REALLY gay kid... name starts with an 'N'... ends in an 'oah'...anyway he's got a 'special edition' type mortar that I'd be more than willing to introduce to my dashboard.
