Posted June 18, 201015 yr I have 2 kicker l7 15 inch subwoofers in a dodge charger,the amp i had was a kole audio 2400 watt amp it cost 150 dollars brand new..well the amp took a dump and i was lokking into the audioque 2200 for my subs there the o6 model kicker at 1000 rms..i wanted to know if anyone has heard or has one of these amps?and would it push my subs pretty hard?sorry for my spelling lol i got the big 3 and gonna be getting a kinetic batt soon.
June 18, 201015 yr ThisSound Solutions Audio Membership - SSA Car Audio ForumandthisAttention NOOBS!!!! - SSA Car Audio ForumWelcome to SSA ....
June 18, 201015 yr it's install dependant and how you wire the subs to the amp will help with power to them and ive heard good things for those amps never used one tho for wireing options you can check out 12 volt .comthe less ohm load on the amp the more power will come out of it for your subs but keep in mind the aq2200d is stable at 1ohm don't recomend going lower as it could hurt the amp Edited June 18, 201015 yr by icy_chris
