Posted June 27, 201015 yr I Have everything connected to where its suppose to be connectedRCA Outputs from HU to imputs on ampPos battery to Pos ampNeg Baterry to Neg ampetc etcWhen i hooked everything up and set the HU to a song all i get is a FULL Burp on my subs.Like the amp is sending full 3000 Watts to it :/I dont know why and its driving me crazzyyywhat do you think is the problem?
June 27, 201015 yr Author And Sometimes when theres no sound RIGHT when i touch the terminal ill hear a Humming Sound...
June 27, 201015 yr Neg batt to neg post on the amp??!!! WTF ?I thought the neg batt should grounded to the frame of the car. And the - on the amp to the frame too for a good ground. Be careful. You seem to do it bad.
June 27, 201015 yr Negative from battery to the amp is fine. That may be the lowest resistance option.Try hooking up a cd player or ipod to your amp and see if it exhibits the same behavior.
June 27, 201015 yr Negative from battery to the amp is fine. That may be the lowest resistance option.I did not know that! Sorry. I learn something new everyday here!Thanks
June 27, 201015 yr Negative from battery to the amp is fine. That may be the lowest resistance option.I did not know that! Sorry. I learn something new everyday here!ThanksThe only reason for grounding in the back near the amp is to minimize wire length and possible resistance. Remember that the negative terminal of the battery is grounded to the car's frame, and so is the metal you're grounding the amp to.
