Posted June 28, 201016 yr I have 2 kicker l7 15's and my amp went into protect mode, i checked allthe wiring and also unplugged my subs and the amp was still in protect mode..Any other way to see if my subs are good or was unpluugging them good enough being that the amp stayed in protect mode?
June 28, 201016 yr check the subs with a dmm if you have one that will tell you for sure about the subs as for the amp try unpulgging every wire and re plug it in if the sub is good reconect it if it still stays in protect its somthing with the amp my old amp did that to me still havent figured it out yet i think it was the power supply that went on mine
June 28, 201016 yr Author check the subs with a dmm if you have one that will tell you for sure about the subs as for the amp try unpulgging every wire and re plug it in if the sub is good reconect it if it still stays in protect its somthing with the amp my old amp did that to me still havent figured it out yet i think it was the power supply that went on minethanks
