Posted July 2, 201016 yr Ok i know this is the ohm load i want but are the coils that are run + to - being used or just the + to + and - to - ones being used Thanks
July 2, 201016 yr Ok i know this is the ohm load i want but are the coils that are run + to - being used or just the + to + and - to - ones being used ThanksYou should be more clear when you post. All of the coils are being used. Be sure that the + to - "jumpers" on each speaker go from one side of the speaker to the other side (ie linking the + from one coil to the - on the other coil)
July 2, 201016 yr They are all powered. The power flows to the + on the one coil from the one sub hooked up to the amp's +, then from its - to the other coil's +, thus giving power to the other coil. It's just like stacking batteries end-to-end in a flashlight.
