Posted September 16, 200519 yr ok, let's start with the stupid question, are 0 gauge & 1/0 gauge cable the same or are they diff & some people just don't realize it? I see people advertise 0 gauge power cable but the pic has 1/0 clearly stamped on cable. 2nd, I will be using 1/0 with an inline 300a fuse approx 4" from batt. It will go into a non fused dist block to 3 amps.(2g out, & 4g x 2 out) Do I need to to refuse between the block & the amps or does the inline protect all wiring past that point? duhhh, found answer to 3rd question! BTW I finally have everything except the wire & alt so in a week or so I will post some pics of everything & the box build. I know how everyone loves pics on this forum!
September 16, 200519 yr 1. Yes, they are the same.2. It is preferred. You can never be too safe.3. Good job!
