Posted September 20, 200520 yr I need the specs on this Amp or someone to help me know proper way to install!!!! Thanks
September 20, 200520 yr Rated 600w x 1 @ 4ohm...but is supposed to be underrated and do closer to 1200w.
September 23, 200520 yr hey, I've had one of those for the past 7 years or so. I'll try to find my manual (I used to have a pdf manual too) and I'll contact you if I do. As far as the proper way to install it isn't any diff than another amp. The four little buttons that are all in a group are your hp and lp and you can just start pushing them and figuring out what they do it shouldn't be very hard.Just a note, I've ran mine for extended periods at 1ohm without problems (the fan only kicks on once in a while when I'm pounding for long periods) but I think its rated by PPI to be stable to two ohms. If you stay at 2ohm you shouldn't have a problemsweet amp 7 years of daily use and never a problemlater,b
