Posted July 9, 201015 yr For a slot port is 2" for the width too small? Will there be port noise? Box Specs:width: 25height: 13depth: 13wood thickness: 0.75port height: 11.5port width: 2port length 1: 10.25port length 2: 14tuning Hz: 37
July 9, 201015 yr yes that is enough port area but if you want it tuned to 37hz the port only needs to be 21.3 inches long if you keep the length that you have it like 35 hz which i think you would like better. next time you build a box use the rule of thumb 12-16 sq inches of port area per cubic foot Edited July 9, 201015 yr by GOT SPL Z71
