Posted July 9, 201016 yr im building a box for 2 15" lethal injections and i need to know the cut id for the subs.
July 9, 201016 yr Author sweet thanks. i woulda txted you but the screen on my fone broke when i was carrying the wood lol.
July 9, 201016 yr sweet thanks. i woulda txted you but the screen on my fone broke when i was carrying the wood lol.
July 10, 201016 yr Author gah i fuck up everything. i just cut the hole for the sub and i wasnt paying attention and cut it right above the port. so the sub is the closest to the port instead of far away. Edited July 10, 201016 yr by iputon326
July 10, 201016 yr gah i fuck up everything. i just cut the whole for the sub and i wasnt paying attention and cut it right above the port. so the sub is the closest to the port instead of far away.
July 10, 201016 yr Author since i messed it up how will it effect it? i mean its right above the port.
July 10, 201016 yr Author im bout to just build a whole other box. i only put one in and havnt even started on the other box yet. or i was thinking just cut another piece and put it over the hole and cut the other one.and i havnt put the second baffle on it yet so i might still be able to fix it? Edited July 10, 201016 yr by iputon326
July 10, 201016 yr Author If you can somehow fix it, I would recommend it.how would it effect the output like it is now?
July 10, 201016 yr Not sure, I have had good results with the woofer farthest away from the port throat.
July 10, 201016 yr Author Not sure, I have had good results with the woofer farthest away from the port throat.alrighty thanks. im about to go fix it now.
