Posted July 21, 201016 yr i built my box for 2 18" but one got busted in shiping i have a big comp coming up and will it be saft to run 1 in 11cuft on about 4k just to get my points up
July 21, 201016 yr With what you have given us I'm going to say no. If you want real help give us more to work with.
July 21, 201016 yr Author With what you have given us I'm going to say no. If you want real help give us more to work with.1 18" treo ssx/psibox is a wall 11cuft net tuned to 35hz160sqin off port amp rd audio d9 run at 1ohm about 4krmsthe box was built for 2 but with all my bad luck i just need to get by this weekends comp for points but i will have the other sub in a few weeks i hope
July 21, 201016 yr It will make noise. Power handling will be very reduced in the larger box, though, so lower the gain accordingly or else you're not going to have any subs.
July 22, 201016 yr Author Ok hooked one subs up sounds good on the highs but the lows sound like mudd so when I get the other sub back should I add to the port to tune lower?
