Posted August 6, 201015 yr you guys think its worth rewiring the factory wires on the door speakers with new 16 or 18g?..do they all have to be wired to the front and then to the back ?..do they have to be wired together on a specific side for noise reduction?..thanks for the help i curently have them wired to the hu will be putting a 100 watts into each of them with a 400.4
August 6, 201015 yr What amp? I personally like to run my own wire from the doors to the amp. No need to run on a specific side of the vehicle. I would use 16 gauge.
August 6, 201015 yr Author how did you run it? did you go back to behind the head unit and then run it to the back or did you make you own route to the amp
August 6, 201015 yr From the amp to the door speakers direct. Through the boot. You can use the fatory wiring behind the dash, just make sure you have the right polarity.
August 6, 201015 yr Polarity is the way in which you have them wires. In short Normal Polarity Pos to Pos and Neg to Neg. Reverse Polarity would be the opposite. The BOOT is nothing more than the factory wire cover in the door jam..
August 6, 201015 yr Author you mean phase .. so they should be in the right phase pos to pos and neg neg evrywhere
August 6, 201015 yr how did you run it? did you go back to behind the head unit and then run it to the back or did you make you own route to the ampWhat does this mean? Just use wire directly from the amp to the speakers. You don't use the speaker outputs on the head unit. If your head unit has RCA outputs, use RCAs to get the signal to the amp.
August 6, 201015 yr you mean phase .. so they should be in the right phase pos to pos and neg neg evrywherephase and polarity are the same thing. And we already talked about this in your other thread.
August 6, 201015 yr Author yea true that i was thinking the same thing..what i meant earlier was having the wire run from the speaker directly to the amp instead of routing it through the front where the factory wire is
August 6, 201015 yr Why would you want to run it to the front? The factory wires go there because they are hooked up to the head unit for power.
August 7, 201015 yr Author i have to run the front speakers thru the boot in the door jam anyway so they have to go foward before they can go backwards is what im tryin to say
