Posted August 23, 201015 yr Hi guys,I 'm always trying to improve my system.I have a 15" xcon and a 1500 watts Sundown saz amp.The car is a hatchback toyota Auris, with a little trunk.I had a slot ported box with sub up and port up, at 3.5 ft3 at 32 Hz. This box was too big for the trunk, but I thought it was not the right one for my car. I've heared this same box in a smaller car, with the same setup, and it was ...insane. In my car, it was not really loud.I have, now, a 3ft3 sealed box, with the sub firing back ; I found it was better than firing up.So, here is my question : if I want to do another ported box, what would be the best choice ? Sub and port firing back, or sub up and port back (crx style?) ?What side should I put the port ? Passenger side or driver side ?I don't want to build too much boxes ! Wood, glue, and all, are not cheap around here:puzzled: . I want the best output for my system.
August 24, 201015 yr Keep the box as far back in the vehicle as possible and keep the port as far to the rear as possible.
August 24, 201015 yr Author Keep the box as far back in the vehicle as possible and keep the port as far to the rear as possible.Sorry, but I can't see what you mean. Can you show me a pic as an example , please ?Where to put the sub ? firing back or up ?I think I want the port firing BACK.
