Posted September 10, 201016 yr i drive a 2003 toyota tundra access cab with the door tweeters and i want to get a component set that will go well with a 15" fi bl. what do yall think i should look into?
September 19, 201015 yr The number of responses you've received is a direct result of the quality of the question asked and information provided.For starters, please read the Noob Posting GuidelinesWith the lack of information you provided, anything we say will simply be a shot in the dark. I don't know if I need to suggest a $100 5.25" 2-way component set or the $7000 Rainbow Platinum 3-way component set. We don't know what size speakers you are looking for, your budget, your goals for these speakers and setup as far as output and sound quality, which speakers you plan to replace (both front and rear or just front?), how you will be powering the speakers, if you are powering them from an external amplifier what amplifier and how much power you would be using, how you plan to install the speakers (stock location w/ no modifications, stock locations w/ modifications possible, kickpanels, etc), what music you plan on listening to, what your sound preferences are, how much experience you have w/ past products and what you like/didn't like about them, etc.It's sort of like I Robot.....In order to receive a response, you must first ask the right question.
September 19, 201015 yr Author alright, my mistake for not including enough info. 6.5" component set, just front doors. probly not gonna use the rear speakers. i will be powering with an amp. and for the comp set id like to spend under 300 for nice sounding if possible. im going to try and put them in the stock location. and as far as music goes i listen to rap, classic rock, metal, pretty much everything....
