Posted September 19, 201016 yr hey guys, im purchasing 2 12" Fi ssdIm looking at a ported box, I was just wondering if i need the divider in the middle of the box giving them their own little chamber? or can i just make one bigger port rather than 2 smaller ones ?also aeroport? Is it worth the try ?
September 20, 201016 yr Author im looking at just over 3 cubes (maybe bigger) with displacement tuned to 32-33 hz with L port. Stupid questions but common chamber. is that without the divider in the middle? How do u like that settup? I currently have a 15 BL but need more room height wise!
September 20, 201016 yr im looking at just over 3 cubes (maybe bigger) with displacement tuned to 32-33 hz with L port. Stupid questions but common chamber. is that without the divider in the middle? How do u like that settup? I currently have a 15 BL but need more room height wise!Yes both subs are in the same chamber. For what I listen to it works great, but when the boy plays some of his music it is rather painfull.
September 20, 201016 yr Author i cant wait Last question.If i want to wire my aq1200d to 1 ohm to them. Do i order them both D2 ? or D1 ? i know its D2 for a single sub settup..
September 20, 201016 yr i cant wait Last question.If i want to wire my aq1200d to 1 ohm to them. Do i order them both D2 ? or D1 ? i know its D2 for a single sub settup..D1 with 2 subs.
September 20, 201016 yr Author i cant wait Last question.If i want to wire my aq1200d to 1 ohm to them. Do i order them both D2 ? or D1 ? i know its D2 for a single sub settup..D1 with 2 subs.ok so i order them both as d1 ? then i can wire to 1 ohm ? pushing 600+ rms each ?
September 20, 201016 yr i cant wait Last question.If i want to wire my aq1200d to 1 ohm to them. Do i order them both D2 ? or D1 ? i know its D2 for a single sub settup..D1 with 2 subs.ok so i order them both as d1 ? then i can wire to 1 ohm ? pushing 600+ rms each ?Yes, wire each sub in a series circuit to 2ohms then wire the subs together in a parallel circuit that should = 1 ohm at your amp.
September 20, 201016 yr thank you! cant wait to hear itYou are more than welcome. I hope to see some pictures of your build, good luck.
