Posted September 29, 201015 yr I just got two Audioque HD 12's and I need to know if they will perform well using the SSA XCON dual 12 box design. They will be powered by a 3000d in a 90 Mustang. I sent the box designs to a builder but he is not familier with Audioque. What do you guys think? Need feedback ASAP!!
September 29, 201015 yr No! AQ uses the DD philosophy of tuning in the 38-40hz range and they will suffer in the lower tuned box alignment!
September 30, 201015 yr Author So I should make the port wider and shorter in length to raise the tune to around that level right?
September 30, 201015 yr So I should make the port wider and shorter in length to raise the tune to around that level right?Just shorten it is all I would do. Just remember that those boxes were designed around the SSA XCON drivers.
