Posted October 20, 200521 yr Hi guys,Haven't been on here for a while. I'm wondering if someone would be able to design me a box for my first gen. Mag 15" that would be a perfect cube of 3.5cf (internal) with a 28hz port. I've been trying hard to figure it out but it just doesn't work.Thanks,Max
October 21, 200521 yr How bout a detailed description of how you want it, the vehicle it's going in, and any restrictions measurement wise.I can design evereything for you and provide you with a cut sheet, pretty much whatever you need. Just post the info here.
October 21, 200521 yr He said he wants a cube. I believe theres only 1 solution to that.<{POST_SNAPBACK}>yup! x" x x" x x"
October 21, 200521 yr He said he wants a cube. I believe theres only 1 solution to that.Some people's definition of an Exact cube is different. I also need to know where he wants the driver, the vent, terminal, ect. I'm not about to design a box then all of a sudden have to redo it because I didn't get all pertinent info. Duh.
October 25, 200521 yr How do you design a port... thats for a certain hz?Also if you had 2 mag 15. Could u just do 2 boxes with the boxes together in the middle? double port i think its called?
October 25, 200521 yr Port tuning will be determined by area and length, and enclosure volume.As for you other question, yes, you can.
October 26, 200521 yr 2 ported Mag 15's = BIG ported box. Be prepared for at least 8 cubes before port and driver displacement (that'd be for around a dual 3.5 cube box).
October 26, 200521 yr im still trying how to fit another 15 in my xb without going past the window line
