Posted November 5, 201015 yr Was wondering what would be the best options(in terms of loudness) in regards to size,port direction and sub firing direction.Space I am working with isDepth: 23 inHeight: 26 inchesWidth: 42 inchesSo I can fit a decent sized box in it.car looks likeThat one isn't mine but it gives you an idea of what I am working with, but will have inside pics up tomorrowI appreciate whatever help I get.
November 5, 201015 yr Sub firing up and port either up or to the rear. If firing the port rear make sure you have enough room for the port against the back!
November 5, 201015 yr Author Sub firing up and port either up or to the rear. If firing the port rear make sure you have enough room for the port against the back!It angles down as its a hatch but from top to bottom about 3" to 8", is that enough? And how many cubic ft. do you think the box should be?
