Posted November 16, 201015 yr He's such full of it, lol He's preeching to my class about how people these days do things wrong,such as.It is just as efficient to run one battery, and a crap load of alternators would be more sufficient then to have more batterys and 2-3 bigger alts.Probably true, but then he's talking how you can't be supplying your amps with just battery's of the amount of power it's rated to do, saying that they'll die within seconds, we all know it could happen, but cmonnn. Edited November 16, 201015 yr by ManRossDamn
November 16, 201015 yr It won't die within seconds..You must consider if you draw 2000 watts out of your battery, then you must have 2000 watts worth of alternators to replace what you have just taken out.Otherwise over an extended period of time things will eventually go..dead Efficiency is somewhat of a joke in car audio anyhow...because you are only getting 1% out of your speakers, vs what you put into them. 99% of the energy in a 94.1dB 1w/1m speaker is wasted as heat.
November 16, 201015 yr Author Dang.. Haha, that's what I'm saying, that a battery won't just completely start draining so dramatically, and yes, he was actually targeting 2k watt amps
