Posted October 25, 200520 yr need some help as the website is a little scarce on detailsI have 1200watts (600x2 actually), and im thinking of two si d2's sealed in 1 cu ft eachgood idea or no?#2 for those that have one can yo do me a favora)whats the mounting depthb)overall diameterc)OVERALL depth (from magnet to surroundtrying to see if I can fit two of these or notthx
October 25, 200520 yr Overall diameter is 12.5"Can't help you on the rest as I have a different basket and I'm sure the measurements aren't the same.
October 25, 200520 yr Mounting depth is 6.75". Overall depth is ~7.5", although you will need more than that if you plan on sticking something directly in front of it and making the cone move at all . The 11 1/8'th measurement is a bit on the large side also.
October 25, 200520 yr Author THX A TONthat was super fast off to design a center console with one now instead of two lol1000-1200w @ 1.2 cu ft will that blow the woofer?i dont want to spend this type of cash and be out of warranty
October 25, 200520 yr THX A TONthat was super fast off to design a center console with one now instead of two lol1000-1200w @ 1.2 cu ft will that blow the woofer?i dont want to spend this type of cash and be out of warrantyAs long as you are careful with it. No clipping and no abuse and you'll be fine. In the center console though, I can GUARANTEE you won't even need that absurd amount of power. Try it with low power first and see how you like it. You'll be surprised. If it's not enough, change the coil wiring and get the 1K. Adjust the gain accordingly.
October 26, 200520 yr ^ what Tirefryr said. Our voice coils can smother a Coke can. 1000 watts of clean power is not a problem.
October 26, 200520 yr Bloody hell, with 1500 clean watts the 15" Mag doesn't move much at all in 2.5 sealed...and at that volume it's retarded loud...seriously...
