Posted December 2, 201015 yr so i'd say about 4-6months ago i thought i damaged my RF power hx2 15 and was looking for a recone. it was making a noise like tinsel slap or dustcap rattle. i found a recone w/ coil and suspension upgrade to the team fosgate version. but i built a different box and it stopped makin noises so i thought it was the box. my box is way to big for my current car so i pulled the sub out, put the box in the garage and noticed this befor i put the sub up in the closet btw since its been a blown coil this whole time, the other working coil has been taking an saz1500 at full power......the reason for the coil issue was i went a lil to hard on the sub when i got the saz1500......and the sub was still brand new so i learned my lesson to break em in first
December 2, 201015 yr the reason for the coil issue was i went a lil to hard on the sub when i got the saz1500......and the sub was still brand new so i learned my lesson to break em in firstNo, "break in" has absolutely nothing at all to do with the damage. What you did was apparently overpower the driver. "Break in" is never necessary. Maintaining control of the power you are delivering to the subwoofer, however, is always necessary.And yes, only a recone will fix it.
December 2, 201015 yr if you burn a voice coil it dosent mean the other coil accepts all the given power.
December 2, 201015 yr Recone for sure! As for the taking the saz full power, your way off, considering the imp would change since you went from 2 coils at X resistance down to 1.
