Posted December 16, 201015 yr unless you run into problems with the coil heating up and the ohm load going up to the point were the sub gets less power ...I dont see how you would not be able to tell the gain from the extra 1000 watts...its a btl....Just dont play it to high < aka over heating coilsand dont play it to low < snapping lead wires...I seen alot of people run 3k to the triple stack btl's and the style before the neo'ssay what you want but alot of people are doing it... and there subs dont even get hot...
